Upgrading 2008 Leon Radio To RCD 510?
Jodrell
61
Hi all.
I'm a new convert to these cars and loving it!
However, I am trying to find out if it's possible and how to upgrade normal Seat MP3 Radio/CD to the newer VW RCD 510 on the 2008 FR 2.0 TDCI 170? Can you get the surround trim to match the dash and the radio like the newer models? Is the wiring behind plug and play?
Many thanks in advance! ;)
Jodrell
Jodrell
61
Pretty please?
I've plugged in the 510 but doesn't switch on?
Do I need to adapt the quadlock. :cry:
Cheers!
Jodrell
61
Hi.
Thanks for replying.
I've been to three main seat dealers and they haven't s clue what I'm on about!
How do I get it coded in? I really want to get rid of the standard radio! Ha ha!
Is it normal to be not working at all before being programmed in?
Cheers mate!
jordanogrady
290
These sterio's look awesome. Im looking at getting another seat, but wanted the later 2009 model for the new interior, but I think one of these would convince me to get an older car, and stick one of these in....
Are they a good system? iPhone Bluetooth compatable?
Jodrell
61
Thanks again mate.
I'm from your neck of the woods!
I'm not thick but how could someone code the radio without having it with them?
I wish I could get why it didnt switch on after plugging in. I have the radio code as its new.
Which seat dealer do you recommend getting the trim from?
Also the new 510 has a double antenna input and only one on the car's loom? Can you get a splitter?
May 7, 2011
1,044
North East, UK
Thanks again mate.
Sorry is it me your 10mins from??
I would happily help!!
I am here: http://maps.google.com/maps?ll=54.791528,-1.490727
May 7, 2011
1,044
North East, UK
Don't worry about age!!
I have a 2011 Leon and the only thing I have found is you need the VW version to get it to work seamlessly with the newer models!!
My RNS510 system works perfectly!!
Granted you have to be brave to cut your dash, but you do gain the use of a SD card slot on the VW version!!
I am here: http://maps.google.com/maps?ll=54.791510,-1.490672
Jodrell
61
Yes sorry mate.
I'm just up the A1 from you.
I would really appreciate your expertees!
Can you email me?
Jodrell
61
I have been trying to get it working with the 310 before I get a 510. Is it better to wait till I get it before checking it out?
lofty987
Im also fitting an RCD510 to my 2007 Cupra to replace the standard radio. Following advice from the posts I have bought a Seat RCD510, dab antenna, the antenna split converter wire, aux cable and have a fascia to fit the RCD510 on order. I’ve plugged in the unit and the screen doesn’t come on but can hear the disc making noises. Where is best to source the power for number 16 pin? And also do I need to do some cutting at the back of the hole left by my old unit as I’ve tried to fit the new unit and it won’t go in far enough to be in the right position. Any help would be appreciated.
SWANSWAY CUPRA Dealership
