SEATCOOBER
LOVE MY IBEEZA!!!
Mar 11, 2007
1,400
LINCOLN/NORWICH
as title says im going to be doing the g60 fly wheel and vr6 conversion soon just wondering if there is any tips or handy pointers as im going to be doing it my self!!!
hi mate, i need to put a new clutch in my car, and was goin to uprate at the same time. where did you get the g60 flywheel from? and is it just a standard mk3 golf 2.8 vr6 clutch?
Matt
Matt
people get the flywheel from ebay or find them on the vw forums. and they use a luk or sach clutch for the conversion but i have seen that euro car parts do a valeo kit witch has a flywheel clutch kit set for just over 200..:D
is this valeo kit everything i need? is it a vr6 kit or a g60 kit. also will i need to change my starter motor. i did a search but couldnt find anything. feel free to post me a link, still a noobie so not brilliant at finding everthing, sorry..
was expexting it too be more than that so i will deff get the valeo. thanks for the help..:)
wil this valeo clutch kit be ok for the power im running as i reallyh dont want a sporty clutch and feel really harsh and i dont want much vibration!!
im after a new clutch for mine not sure if a vr6/G60 combo will be ok for the power your running m8 i have the same turbo and wanted 2 fit the same clutch but not sure if it'll hold the power (someone correct me if im wrong) as all the other clutch's ive looked at that are rated to 300bhp plus which you probably are are around £500+
Got a spec stage 3+ clutch waiting to go one mine. Ment to be VERY good clutches and can take alot of power! Not cheap though....worth looking into though
Im quite pleased with my spec3+ with G60 Fly, does need aprox 500 rpm more then standard when pulling of from start but you easilly get used to it. Did stall my engine a couple of times the first day I to her for a spin thou:) Im not running big (k03s) figures but didnt want to end up changing again if I go BT at a later occasion and I dont feel its a overkill on my setup.
Prebs
