Something I found out with my DSG 'box today.
After some 'spirited' driving on country roads with the box in S, I came down a steep incline into a 40mph limit, so moved the gearbox to D and took my foot off the gas. On the flat, the DSG would have gone up the gears until the revs were about 1000-1500rpm, but on this occasion, they stayed close to 3000, like an experienced driver would with a manual 'box.
There must be a tilt sensor, or some accelerometer setting that senses when the car is not slowing down with no gas in order to use engine braking. It's not something I've noticed before.
Some awesome ones here
However, one of these says "Using the VAGCOM settings", or "If you have bluetooth".
I have bluetooth on my car, but how do I access some of these settings?
Generally if you have bluetooth you will also have the larger rectangular multi function display in between the speedo and the rev counter. You get extra menu options displayed in here.
You should be able to access those menus using the menu button and rocker switch on the right hand steering wheel stalk, which should bring you to some of the convenience menus.
***** Be aware that this setting is not allowed in many countries on public roads, so be careful *****
Instructions
1. Insert DVD and start Playback.
2. Move the car until the screen turns black and the security message is displayed.
3. Stop the car
4. Press the Voice Command button on your steering wheel.
5. Directly after press the Tone button on the MFD, (you should hear a chime signal).
6. DVD Playback should stop for a split second but continues thereafter.
7. Done!
Don't know if this has been mentioned....
Scenario.....
Your on a motorway with cruise set to 70mph.
Your approaching roadworks or a part of the motorway where the speed limit is different to 70mph 'say' 50mph
So you knock off the cruise & let the car slow down or press the brake and slow down to comply with the limit for the restricted speed of the road
Now if you re engage cruise the car will start picking up speed to go back to the previously set limit (70mph) however......
If you push the minus (-) on the cruise stalk once, then you'll stop speeding up & the s the cruise controll will stay at the speed you hit the minus (-) and reset the speed limit for the cruise.
Which headunit is that with?
Think mine is RNS310 , dunno if it will work but ill try it anyway
CR's have 315s but I think DVD ability is 510's instead
is it a 315 I dunno ill have a look in the book , mine is a 62 reg , do they not play them then ? I don't wanna stick on in and get it stuck lol
The FL model got the newer but shiter sat-nav's unfortunately, but you could maybe get one of these, no idea if it actually works but it would be pretty cool, I reckon you could fit an oldschool PS1 in the glove box lol (thats PS1 not the first Playstation btw) http://www.xcarlink.co.uk/product.php?productid=104&cat=2&page=1
Did this a few times on the old stg2 CR170 and it does indeed work, but it won't shift to 2nd for you. So you need to be real quick and any gained made on the launch are lost if you don't time the shift to 2nd perfectly.REG DSG GEARBOX LAUNCH CONTROL
never tried it my self but I am told it works by someone who has done it
selector in S ,
traction control off,
foot on brake,
other foot on gas to the floor and when the revs settle at 2500,
release the brake
