V5(170) EPC light
Har
105
Fife Scotland
Got the EPC light on the dasboard,something to do with the throttle pedal but the car seems to be driving ok,also plugged a diagnostic tester and coming up clear,any ideas:(
Tonoa
EPC light
Hi Har,
Have you recently replaced a rear light bulb?
This happened to me - one of the bulbs I replaced should have been a double filament one instead of the single filament I replaced it with! Once corrected it worked perfectly and no more EPC light. Worth checking out.
Deleted member 5241
I think I know what the fault is on this...I had the same thing on my Toledo TDi.
Its the brake sensor on the brake pedal!! :wtf: The fault I got on mine was the glow plug light was on (wont affect you :D) and I had no rear brake lights at all. That was dangerous, but the thing that threw me was that I had no cruise control either, so I had two unrelated symptoms that I could see.
Try taking off the lower panel near the brake pedal and playing around with the switch, its a common fault and one that can be remedied by replacing the switch with a later version.
Its a weird switch, if you take it off and have a play with it you will see that it ratchets out, this extra extension is taken up when you press the brake the first time. Instead of replacing it you could try turning it a few mm either way to clear the fault.
HTH, I see you are selling your motor on P'heads. I've got a V5 Golf 170 now, but I don't think the Golf is worth the extra money over the Seat TBH. Think I may be in the market for one in the near future.
Har
105
Fife Scotland
you were right it was the brake light switch,everything is fine now,just need to give the car a good wash now,give me an offer on the SEAT, i had a v5 golf 2 years ago really liked it:D
MartinWilton
Thanks very much man. I will try that and let you know.
Take it easy
MartinWilton
EPC Warning light.
fgdf
