MikeA
MAF Destroyer
Nov 14, 2005
92
Northants
I'm at the stage where several of the hoses are beginning to perish / split.
I need to know if anyone does a replacement kit or is it just a case of buying a load of silicon hose and cutting it as required.
Want to get this sorted before I go for a remap or it'll just cause problems.
Are there any hoses that I should know about that arent in a visible place?
Mike
so r these an essential before re-mapping and further mods then??
Id say replace them anyway split or not there gunna be 5ish years old at least, for a tenner it could save you abit of trouble in time to come
yer defo m8, ill bear it in mind, any specific make?? samco??
I used an ebay company cant remember which one, i got 5meters of 3mm internal diameter red silicone hose and replaced them all, you dont need and clips or cable ties using 3mm as its tight enough. Looks better too.
So is that 3mm talking about the thickness of the 'wall' you might say? And what about the size of the hose opening itself? And are these sizes the same for cordoba cupra 20vt 2002 model? I suppose so as its same engine right?
thanks
I am sorry but as English is not my first language I still do not understand that...if you have the hose is 3mm the opening of the hose, or the thickness of the walls (i don't know how better to explain that)
thank you that helps yes...hope i wasn't bothering you with that
but then I have one last question...whats a good size with the thickness of the hose then?
and was I right saying that for cordoba cupra its the same measurements?
thanks
alright thanks a lot
When I buy them and place them I will post some pics. Actually I still haven't posted any of my car...gotta find out how
Hey got another question:
How do you fit the hoses over the parts? Isn't it extremely difficult as it is such a tight fit?
thanx ;)
