Phillips1795
VCDS - How To Guides - MK3 Leon 5F
TOLGAHAN KARTAL
Can anyone help me ? I want a open esp sport and esp off but in my code there is no byte 29 how can do?
20EE6A9220212A71007D060801CC240456045400608024F200290020C0
this is my
03-abs
07 codding
long codding code
my car leon fr 2013 1.4 tsi 140 hp
Ash82
148
37
Manchester
I
I’m going to go through vcds software again at weekend
think I’ve found some hidden codes using a different software odb carista , however my vcds didn’t pick them up? 3 fault codes I’ve cleared them and it seems to have worked, if anyone is having issues like me it could be hidden errors?
yanivkoval
152
32
Hi everybody! I have a very simple question: Can my Cupra, with this head-unit play videos from USB, or SD? 50A 035 846; HW H24; SW 0245. Thank you for your reply! The fotos are working, but from video files comes only the sound, without picture...
No it can't. Only the models with the satnav are able to play videos (during stop).
I think that they are called "mib high".
Also this is illegal in many countries.
I have researched the same thing a year ago, and the only solution I have found is a device called video interface.
Basically it is an android box that is attached in between the head unit and the display and you can switch between them.
Good luck :)
Sent from my SM-G965F using Tapatalk
Ninja10R
194
30
Athens, Greece
www.trackbike.gr
this is my
03-abs
07 codding
long codding code
Ill share with you coding for old ABS unit (2013-2014) which doesn't have byte 29 to do coding for ESC Sport/OFF. This unit usually has finished with byte 28 value C0 s TPMS or value 40 without TPMS.
If you want ESC sport/OFF on this unit change coding in byte 25 mark bit 4
After this you will get this setting menu
I found the above in this forum (i don't remember the thread). It hasn't helped me, as my 2014 FR has byte 29, but the previous owner had changed the infotainment with a S160 Android unit that the only thing it shows is ASC activated or not activated whatever change i do.
aBoijj
104
Midlands
Good luck :)
Partially incorrect - the presence of sat nav is irrelevant in this case. I have sat nav but because I don't have the Navi System Plus (as Seat call it) I can't play video. Navi System Plus can play videos up to 720p as long as they are in a supported format.
Source: Seat "Media System Plus - Navi System - Navi System Plus" manual.
https://www.seat.com/datamanual-inf..._w45/en-uk/MSPLUS_NS_NSPLUS_LEON_11_17_EN.pdf
iby104
76
10
Il test my leon fr (2017). I did manage to get my phone working with full link before, using lg app, but it doesnt work anymore. I think samsung updated their software and blocked my phone
Sent from my SM-G930F using Tapatalk
Ash82
148
37
Manchester
Can anyone help to program Speedo lights to stay on all the time -
The screen shot won’t load
Codes are
Terminal 58xt bus
Terminal 58xd log bus parking light
Terminal 58xs bus
Terminal 58xd log bus terminal 15
Not available
The first code was already set at. If you can help me put the correct one that would be great.
Kisszabo
31
Hungary - Győr
Hi friends! I updated the SW my Leon ST290 from 245 to 346, and i have a strange problem: the Sport display reset itself every time... i set up the followings dials: Turbo load, Oil Temp, Water temp - and the next day the turbo, the g-senzor, and the Power meter (KW) is there... What is this error? Could you please help me? Thank you! (pic is from the net)
Kisszabo
31
Hungary - Győr
Codes are
Terminal 58xt bus
Terminal 58xs bus
Not available
Try here, maybe solve your problem...
Adjust the sensitivity of the light sensor
With this modification you can adjust the sensitivity of the light sensor.
1 - Module 09 - Electronic. Code (31347)
2 - Adaptation
3 - Select - Functions assist light
4 - Sub - Lichtsensorempfindlichkeit
5 - Select one of three options:
- Normal (default)
- Sensitive
- Non sensitive
May 21, 2019
8
Hi
Hoping anyone can help
did some coding with the VCDS and unlocked most features, however i just noticed my sat nav screen now shows a Golf and not a Leon anymore !! please help, the optical parking is also showing the VW version and no longer the Seat Leon version. Start up screen shows seat leon FR but when in parking pilot its completely different now and the car that shows up on the screen is a GOLF! not a leon like before. Can anyone tell me how to solve this or where i've gone wrong?
Also since i did the coding straight after my sat Nav said "The navigation data in the SD card are not valid. Please check data"
Clodius
26
London
I've seen on the obdeleven topics that you can activate the rear optical parking sensors. Can't seem to find this with VCDS
Aug 21, 2019
Working like charm :rofl:
STG 09, 31347, Adaptation,
Left Side
(4)-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Ambientelicht 4
(5)-Leuchte 0 BLK VL B36-Lichtfunktion B 0,Blinken links Hellphase
(6)-Leuchte 0 BLK VL B36-Dimmwert AB 0,127
(8)-Leuchte 0 BLK VL B36-Lichtfunktion C 0,Blinken links Dunkelphase
(9)-Leuchte 0 BLK VL B36-Lichtfunktion D 0,not active
(10)-Leuchte 0 BLK VL B36-Dimmwert CD 0,0
(11)-Leuchte 0 BLK VL B36-Dimming Direction CD 0,minimize
(12)-Leuchte 0 BLK VL B36-Lichtfunktion E 0 – Blinken rechts beide Phasen
(13)-Leuchte 0 BLK VL B36-Lichtfunktion F 0 – Blinken rechts beide Phasen
(14)-Leuchte 0 BLK VL B36-Dimmwert EF 0,0
(15)-Leuchte 0 BLK VL B36-Dimming Direction EF 0,minimize
(16)-Leuchte 0 BLK VL B36-Lichtfunktion G 0, Blinken links Hellphase
(17)-Leuchte 0 BLK VL B36-Lichtfunktion H 0, Blinken links Hellphase
(18)-Leuchte 0 BLK VL B36-Dimmwert GH 0,126
(19)-Leuchte 0 BLK VL B36-Dimming Direction GH 0,maximize
Right Side
(4)-Leuchte1BLK VRB20-Lichtfunktion A 0,Ambientelicht 4
(5)-Leuchte1BLK VRB20-Lichtfunktion B 0,Blinken links Hellphase
(6)-Leuchte1BLK VRB20-Dimmwert AB 0,127
(8)-Leuchte1BLK VRB20-Lichtfunktion C 0,Blinken links Dunkelphase
(9)-Leuchte1BLK VRB20-Lichtfunktion D 0,not active
(10)-Leuchte1BLK VRB20-Dimmwert CD 0,0
(11)-Leuchte1BLK VRB20-Dimming Direction CD 0,minimize
(12)-Leuchte1BLK VRB20-Lichtfunktion E 0 – Blinken rechts beide Phasen
(13)-Leuchte1BLK VRB20-Lichtfunktion F 0 – Blinken rechts beide Phasen
(14)-Leuchte1BLK VRB20-Dimmwert EF 0,0
(15)-Leuchte1BLK VRB20-Dimming Direction EF 0,minimize
(16)-Leuchte1BLK VRB20-Lichtfunktion G 0, Blinken links Hellphase
(17)-Leuchte1BLK VRB20-Lichtfunktion H 0, Blinken links Hellphase
(18)-Leuchte1BLK VRB20-Dimmwert GH 0,126
(19)-Leuchte1BLK VRB20-Dimming Direction GH 0,maximize
What’s the originals as my indicators aren’t right
Aug 21, 2019
Left Side
Right Side
Hi this put my orange lights on on sports mode but my indicators front are all messed up cannot send video but left indication is making both orange lights flash instead of jus the left and when right indicators on the dlr is flashing only without orange light how do I fix this thanks
