sala7
59
KUWAIT
if any one knows how the vcds programming the wondows rolling up/down from key fob like KVW100 ,
i need to know the steps and coding on VCDS if avalible plz
That programme is far better than KVW100. There have been reports that KVW100 locks the ECU after it's finished, which causes issues if you want to work on it again.
I'd use that programme over KVW100 anyday. It does the same job.
thanx too much lee69 , thanx too much slimy , u r very kind , u guide me too much the day i join that forum ,
I hope to become a friend to both of you
i installed the program & i'll use it once i get the cable , just today i ordered the ELM327 usb cable it's better than the KKL vag-com cable that the motordiag refer to ,,,
thanx much
The ELM327 cable may not do the windows, it's a more generic OBDII cable that works with more cars but doesn't work as well with SEAT's.
