Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
How did you get the white fogs??
car looks lovely matewere did you get your pressed plates & HID's from??
I do like them, the black just seems to match the tints nicely though! Did you manage to sort the dual headluight problem out in the end mate?
Can get pressed plates off ebay. I'll send you a link when I'm on computer.
Best place for HiD's is hids4u.co.uk (or .com)
Sent from my BlackBerry 9800 using Tapatalk
What bulb type are the fogs??
HID fogs. I've got some. Bitch to fit but look good.
You can get LED fogs tooo cant you? Wouldnt that be a lot easier than doing all the HID stuff?
Yeah LED's are pretty dim because you have to put a larger fuse in or they just blow immediately, and if you get larger ones then they dont fit in without removing the metal cap inside the fog, which means you're better off with HID's in terms of brightness.
Hmm, could the fuse thing be why i get through a load of sidelights and led number plate lights?
