VR6 Clutch with Eurospec G60 Flywheel Kit, 14 lbs
black pearl
Newbie
Feb 10, 2006
55
I was just looking and this came in my sight///
is this a good kit for the cupra ?
the price is also nice...
A big seller for us here at MJM, the SACHS VR6 clutch kit with G60 flywheel combo is a great way to upgrade your MK4 2.0L, TDI, or 1.8T clutch kit and go with a bigger, beefier 228mm clutch and flywheel package.
Rated at near 300 ft/lbs of torque, the SACHS VR6 clutch kits can take nearly all you throw at them - all while retain stock like pedal feel. The Eurospec single mass billet steel flywheels tip the scales right at 14 pounds and come with factory ring gear.
The Corrado G60 and Passat 16V's also accept the VR6 clutch. This kit is a great upgrade for those models without spending the big money.
All kits includes:
SACHS VR6 Clutch Disc
SACHS VR6 Pressure Plate
SACHS OEM Throw Out Bearing
Eurospec Single Mass G60 14 lb. Flywheel
All OEM pressure plate (6) and flywheel (6) bolts ...
cost $399.95
let me know what you think about it
Jonzy
I picked up all oem stuff g60 fly/vr6 clutch in a group buy from ukmkiv's... 250 delivered.
Jonzy
Sitting in my kitchen at the mo craig, numbers are
Fly - 037 105 273 A
Cover - 021 141 025 FX
Friction - 021 141 031 CX
Bearing - 02A 141 165 A
I cant say if they fit but im told that they should.
Tha Spank
Newbie
Oct 26, 2005
50
Netherlands
Fly - 037 105 273 A
Are you going to use the flywheel as it is (10kg)? Ore are you getting it lightened? How much torque can the OEM vr6 clutch take?
This sachs set isn’t expensive 210 pound, but what should shipping cost? This same set cost 600 pound in the Netherlands:( .
Think I’m going for spec stage 2 (also on the mjm site).
@Bjorn so you’re also spamming SCN mate:p
KEF A3 20V T
has anyone inported this kit? if not are the parts all oem and where is the best place to get them?
Triple D
£210 is that for just the clutch? :roflmao: id sell you one for half that and still make a heafty profit :lol:
Triple D
i work for sachs, hence why nobody can get a clutch cheaper than me. And i doubt that the flywheels are gonna cost £210
