ibizacupra said:No more power on mine but it remained very very consistent.
That's also what i'm seeing on my vag -com, temps rarely go above 50 degrees C and that's with the smic. So W/M/I and A&M's FMIC will keep things fairly cool indeed.
Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
and EGT to 820C area. Running a 0.8mm injector installed just after the OEM smic. 100% water was injected.
Retep said:Has anybody tried using a circuit of the waste gate solenoid
There is no point in pumping water over the intercooler when the waste gate is open
I am currently designing a circuit to pump when the waste gate is closed and has anybody got any pics of the spray nozzle set up
GBA OBD Tool
Shock_Xe said:looks cool, would be nice to have a pda version
ibizacupra said:sounds pretty cool.
wondering if it will work with my aging 3900 iPaq
Feel said:Mike & Bill - it *should* work fine. The 3800/3900 might be "old" but they're good little units. It's a cheap enough solution (if you have a serial ODBII cable) to try it and see...
Be aware that you might have a problem keeping the ipaq charged up when in the car, and there's no practical way of using sat nav and logging at the same time, in fact I have to soft reset mine to get it to connect.
Edit: If you're both at Westec on the 3rd, get the software downloaded and installed and you can try my cable...
just need to find it and the null modem bit from my desk somewhere... must tidy up.... must resist.... arghhh
