thanks for the help guys, i cannot feel any damp behind the glovebox but i shall take a good look on friday when im not at work.
Its a 3door. And your black ibiza is looking really sexy!!
I had black KEI's on my yellow ibiza until i snapped one up a kurb along with driveshaft, wishbone and track rod, and damaged the hub. so got the standard seat wheels on until i get another kei wheel.
hahah rash.... i want your car!! will swap you... its my first car, past my test in it so it has historical value. Its a lil 1.4 so good on fuel. Bright yellow, ull never loose it and it comes with a packet of mints in the door pocket. :-D
loving the art guiness mines a bit lower !!! n0ble this is my first car under my own name at 18
on subject as trumpetman21 said if window sealer is not applied evenly around all windows leaks will occur try running a hose over the car and get a mate to watch and listen for water!
its a common problem leaks from badley sealed doors!
and trust me im not rich at all and ive earnt every penny to get my car and insurance payed (not mummy and daddy!) and every months pay packet goes on keeping it on the road and modifications
did you fix it? oz my next door neighbour had the same problem... we found if you take out the pollon filter and look inside there is a hole which looks down on the inner-arch.. well instead of rain water draining off down there it was goin down the back of the panel and dripping into the footwell..
took the plastic trim away and the carpet by the door and where 3 wires run down and are held in by a clip, thats where the water was coming from inside the panel from in the engine by!
i got exact same problem with rear passenger footwell, i have put my own amp cable through the front, but its been there for 3.5yrs without any problems until now....
