is it a 5door or a 3door matey???? could be loads of things but ive posted them up about 20 times now do a searchy !
thanks for the help guys, i cannot feel any damp behind the glovebox but i shall take a good look on friday when im not at work.
Its a 3door. And your black ibiza is looking really sexy!!
I had black KEI's on my yellow ibiza until i snapped one up a kurb along with driveshaft, wishbone and track rod, and damaged the hub. so got the standard seat wheels on until i get another kei wheel.
Thanks again.
where ever rash is right now his head has probably grown an inch in diameter :lol: and a he has a small grin and he doesn't know why lol
his car is damb nice tho :D
Just got our leon cupra back after having a leak repaired. The water was going in through the bulkhead and running along the wiring loom.
No sign of it happening to my Ibiza yet, so fingers crossed.
Good luck plugging the holes!
thanks its looking like its going to be the bulk head thats what everyone else seems to think. Hope i get it sorted on friday its annoying me.
hahah rash.... i want your car!! will swap you... its my first car, past my test in it so it has historical value. Its a lil 1.4 so good on fuel. Bright yellow, ull never loose it and it comes with a packet of mints in the door pocket. :-D
no words needed
:lol: loving the art guiness mines a bit lower :p !!! n0ble this is my first car under my own name at 18 :)
on subject as trumpetman21 said if window sealer is not applied evenly around all windows leaks will occur try running a hose over the car and get a mate to watch and listen for water!
thanks everyone, and rash you must be some kind of rich ba***** nice car thow. :p
Was the window seal ( the metal flash panel) , the stealers had not put it back right....
its a common problem leaks from badley sealed doors!
and trust me im not rich at all and ive earnt every penny to get my car and insurance payed (not mummy and daddy!) and every months pay packet goes on keeping it on the road and modifications :p
did you fix it? oz my next door neighbour had the same problem... we found if you take out the pollon filter and look inside there is a hole which looks down on the inner-arch.. well instead of rain water draining off down there it was goin down the back of the panel and dripping into the footwell..
took the plastic trim away and the carpet by the door and where 3 wires run down and are held in by a clip, thats where the water was coming from inside the panel from in the engine by!
i got exact same problem with rear passenger footwell, i have put my own amp cable through the front, but its been there for 3.5yrs without any problems until now....:confused:
did you manage to fix your problem?
