how does it work? like is a controller req? does it run on the same principal as nos in the form of only being injected at full throttle?
Not sure if all kits are the same, but my Devils Own kit, takes a pressure feed from the boost pipework, which connects to a pressure switch. This can be adjusted so that the pump kicks in at different pressures.
You can get progressive controllers, but on diesels theres very little to be gained from having this.
