What did you and your MK2 do today?
Jan 3, 2014
593
Okay so finally got to the bottom of my misfire.
Did a resistance test on all my injectors 2-4 were at 2.5 ohms and cylinder 1 wasn't even giving a reading. So replaced it with a new injector, and the valves were caked in carbon so have it a clean up with some forte cleaner. Hopefully should run a bit better now :)
I have pictures but don't know how to put them up?
What was the results of misfire? Any running problems or limp mode?
did you remove the inlet mani and clean the valves?
to show picture you need to upload the to an image sharing website then copy the link on here and they should show.
Joshkcupra
Local Retard
Aug 21, 2012
899
Gravesend, Kent
was reassemble as bad as disassemble?
whats that in the last picture?
did you get any pictures of how clean you got the valves?
My phone battery died by that point mate as it was gone 10pm lol
The valves were 1000x cleaner I sprayed them with forte cleaner and left it to soak for 10 minutes and then hacked away at it slowly with a flathead screwdriver.
The reassembly was harder than taking it off yes, the throttle body plastic pipe was a *******!
The last picture is the failed injector mate
DGF264
850
County Durham
Sorry if I'm being dumb, but where did all the crap go josh after u cleaned the valves and hacked it all off?
WeeG
3,407
Largs , Ayrshire
Gave the car an oil change and swapped over the pro race 1.2's and R888's for the standard LCR 19" alloys and Michelin supersport pilots for winter. Currently down south at centre parcs winfell forest fully loaded with bikes and enough of the mrs bags to last me a few years let alone a long weekend!!!:p
969
cumbria
Your just stopping a long the road from me I live in Penrith. I'll keep an out for you.
Daniel M
Blackbelts & Chickenheads
Apr 18, 2013
2,873
7
Middlesbrough
Bought some Sonax perfect finish polish. Hopefully get one more good day in before the winter comes to give it a good detail and get rid of the swirls etc.
Hadnt used it much the past 5 days or so as had a hire car for work, a Hyundai i40. Not a bad car, though very very laggy.
