Fitted a slightly smoothed and drilled air box and gave her a wash...then realised I was gonna be late for work so now she's covered in watermarks
Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
Well today i started taking it to pieces for the last time.![]()
Yeah but i have sold a lot of them so it would be a bit tricky to put it back together.
bit of an update
plasti dip arrived
So i thought id giv it a go on the wheels.
my plan is to do a test coat to see how it holds up and im thinking of doing my whole car mat black.
As this is just a test & i am very lazy i have left the wheels on the car, and im spraying outside in the cold and wind so already i know it wont be done to a perfect standard, but like i said its just a test.
first i cleaned them
then applied a light first coat
then did the first wheel heavy and fast to see how it would come out
but did the other 3 properly and slowly built up the layers
then some water from the cleaning started to drip from the bolt cover & S badge and wreck the dip
but after i pulled the dip off the center of the osf i re did it and touched up all the others
then moved the car back and touched up all of the bits i couldn't see properly
stealth mode
it looks better on the car than in the photos, all thats left to do now is peel the dip from the tyres and maby remove the dip from the S badge in the middle.
*** i know it is not done properly or to any sort of special finish.
This is a test to see if it is worth doing it properly & might convince me to dip the whole car.
Most people use 3-4 cans to do all 4 wheels i used 1.5 so i know its going to be a light/ easy to remove coat and i still have 4.5 cans left for doing it better next time if i like it & it holds up well. ***
Put the clock back an hour![]()
