taff141177
379
crewe
Just removed my multi changer and put the insert in which dave from sere motors supplied and very quick delivery aswell
Plus put these on yesterday
The last image is upside down oops
RaviR50
2,425
Southampton
Just did a temporary fix on the seals, bit of cling film taped to the sills, hopefully that will keep a little bit of the rain out till i can get the bits needed for the fix
Fozzy84
249
137
Took mine to a trackday at oulton park and spent £70 in fuel and managed 11.4mpg average!
Car performed very well and outran some more powerful motors!
dgjdrummer
Part-timer
Nov 5, 2011
1,301
Wrexham, N. Wales
How did you colour your gear knob? Looks pretty cool
Cheers :D whatever you do, DON'T attack the sides of it with a screwdriver and chip it like I did :censored:
Get a small flatblade screwdriver under the little badge on the top and lift this off. There's a screw there holding the surround on (the bit I've painted). Unscrew it and the surround just lifts away, then simply spray and fit back together :) removing/re-fitting takes all of 2 minutes.
Dozer360
mk1 Seat Leon 20v T
Jun 1, 2010
875
southampton
nice, i will have to attempt this now, always wanted mine blue rather than the worn out grey look its sporting atm
Jun 14, 2003
546
Southampton
Thanks for this - cant believe there isn't a Cheeky little guide for this simple mod
dgjdrummer
Part-timer
Nov 5, 2011
1,301
Wrexham, N. Wales
Hahaha I've been thinking for a while we need a guide for all these small mods that get overlooked!
I managed it after about 15 minutes of trying to pry the thing off the top with a screwdriver (and subsequently taking a chunk out of the side) but it would save other people a lot of hassle!
Let us know how you get on with it :D
Dozer360
mk1 Seat Leon 20v T
Jun 1, 2010
875
southampton
couldnt wait, and the GF has :censored: xfactor on [:@].
and i just ordered my trainers to match
i'll have to wait till tomorrow to find out how to get the gear gaiter surround off then paint that to.
RaviR50
2,425
Southampton
I've done mine red,
easy to do, just get the whole thing out, theres 2 tabs either side, then the silver bit unclips with a bit of force, carful not to break the little tabs though it wont go back on otherwise haha
Dozer360
mk1 Seat Leon 20v T
Jun 1, 2010
875
southampton
I've done mine red,
thanks, ill give it a go, is the leather bit attached or can i just take the plastic bit off?
csd_19
2,270
28
Angus / Edinburgh
Was determined to find the cause of the final small water leak into the car (after replacing the pollen filter cover) before refitting the carpets. I pulled the glovebox out and with a bit of contorsionism I was looking up at the bottom of the fan unit, and specifically the closed flap for the recirc setting. At the edge of this I could see some moisture and figured there was still water getting in at the filter. So I removed the wipers, engine bay seal, scuttle panel, rain channels, pollen filter (again) and then the actual pollen filter housing. The housing is held in by two 10mm plastic nuts and a foam seal, one nut is inside the housing with the other one outside, between the housing and the inner wing area.
Once the filter housing was out I discovered this small amount of rubbish:
After inspecting the filter housing closely I could see water had tracked down the inside of the filter housing between the filter holder and the housing itself - with the height of damp leaves behind the housing the water must've been slowly making its way into the housing.
Cleaned all the crap out around the entrance to the fan unit (I hoovered out the few leaves which had fallen in when I took the housing off) - the flap you can see is for drawing in fresh air and closes when the recirc is activated ( and the lower flap opens)
The foam seal (ha!) around the base of the housing was soaking as well, water would've been free to pass through it so I peeled and scraped off as much as possible
before using some of the butyl I had left over from doing the doors to make a new seal
The filter housing and filter were then reinstalled along with the rest of the bits...
Hoping that is it now, it started hosing down about 20 mins ago so fingers crossed this is the last of it....
If not then it's getting torched/sold/broken! :handbags: ;) :rifle:
Dozer360
mk1 Seat Leon 20v T
Jun 1, 2010
875
southampton
just make sure that plastic wing sits on properly and does not get pushed off when you put the rubber bit back, i did that to mine but only found out when i had a swimming pool in the passenger footwell [:@]
Dozer360
mk1 Seat Leon 20v T
Jun 1, 2010
875
southampton
got my gaiter off, didn't know what everyone ment by pushing the tabs so i stuck a flathead down there and it popped out fine
was a bit of a pain trying to separate the top part trying hard not to break it using the interior lights to try and see what im doing
then tried painting it straight away but it wouldnt stick so i rubbed that off and put some primer on first, than that started taking the grey plastic/pain so after scratching it all doen to the clearish plastic i have just put some primer on ready for painting in the morning
