Fitted 80mm silicone ducting into my airbox to replace the standard snorkel.
Adjusted cable tension of door handles as some were getting difficult to open.
Disconnected & plugged EGR vacuum hose. The engine light is on anyway so thought I'd try running without EGR for a while...
Sorted out the undertray fixings a bit better, it was sitting too low and catching on speed bumps after I changed the EGT sensor a couple of weeks ago. Also re-did the R badges again as the ones I put on earlier this year looked tatty really quick so used lacquer this time. Added an extra one for a couple more bhp ;)
Yeah mine are a bit far gone for a coat of laquer. :lol:
I guess it's a caliper off job?
spent today replacing an electrical connecter i managed to destroy drilling through the spare grommit to run to silicone hose for the boost gauge. Easy job, just a pain replacing the disconnector box in such a small space...
Hope you re-sealed that box well, main area where water comes in the car
i did indeed Lee, used the remainder of the black silicone i had from resealing the doors... although i only touched the spare grommit i thought id do all of it given the proximity to the electrics there
Thanks pete best £14 I've spent on the car. They were in abit of a state usual pink fade and lacquer peeling and bubbled up but I'm guessing it could've been worse lol.
Something that's bugged me since forever, had the inner ends of the side skirts sprayed once before but already they are sandblasted by the road rash, to permanently sort this I did this
Here's the issue
So I cut some templates and transferred to 2mm abs sheet and cut these out
Used some oe screws
Eh viola!
Takes the eye of the unsightly rashing, plastic will wear bit not as visible and looks loads better, I think anyway , done this both side obviously :)
Here's the issue
Used some oe screws
Eh viola!
Fancy making me some I hate mine for this!
Sent from my iPhone
Here's the issue
Used some oe screws
Eh viola!
Cracking idea that!! My side skirts look very similar, the yellow is being chewed away by the roads and almost black :/ lol
