I read on the Skoda forum that you can just swap the inner track rods over for the ones from the standard rack and not worry about the hubs/arms etc so just looking for the actual rack.
I've had a price from a guy who breaks LCRs near me who is asking £90, seems about normal for a used one so if that's all I need I'll be going for it!
Did you find the steering was any heavier after swapping over? I've heard it changes the feel a bit but also makes it slightly heavier when parking/city driving.
I paid £60 Inc 3 months warranty for the rack. The steering is heavier but in a good way. I've always found the stock Leon handling numb and light. The whole setup has transformed the car from poor to rather impressive.
And yes on the rack ends, swap straight over
That sounds awesome mate, do you find it turns in a bit better now? I always feel like it takes the car a split second to catch up with me turning the steering wheel!
To be honest money is a bit tight and I'm not looking to track the car or anything, just upgrade this 1 part while I can. If I get the arms with it I may consider getting the hubs and lower arms in future though.
Thanks for confirming that, should be a pretty straightforward job!
I think (touch wood) my EML issue is solved! My mates stupid expensive diagnostic tool said the throttle body needed resetting, so that's done! Also checked for air leaks.......none! And found it has a forge 007 recirc fitted! So I'm a happy bunny again! Thanks for all the advice people
Really straight forward swap.
I couldn't say how the rack alone would affect turn in as I did it all in one. :shrug:
I always found there was little difference in the input from about 2pm to 3pm on steering angle and the front would wash out with under-steer. Since this lot it's grips like mad in comparison, I can get on the power much earlier and under-steer is almost gone!
For anyone in the Norwich area thinking of doing this mod it might be worth giving VAG Shack in Norwich a call. I was offered the full front setup (subframe, rack, wishbones, hubs, arb and struts) for £150. All off a mk1 TT 2wd so hubs were a direct bolt on!
I have done a few things recently which are explained in my RR but may aswell share this one as I fitted the lights back on today after tinting:
Masked up
Darker
Getting there..
And the result:
Plenty more in the pipeline for this season ahead of our regular AMD SCN rolling road day on March 22nd.. :D
so are you planning on keeping the Spanish stig now then and not selling it mate?...good looking car that is, with plenty spent on it from the look of it :)
Blew the boost pipe off from the EGR on the slip road to the M4! must not have pushed it in far enough before putting the clips back on Doh!! All good now :)
New battery fitted, finally put the ISO connector into the head unit for the radio to work, washed and cleaned up.
Bought new discs and pads for front and rear just need to fit them now.
Thought about buying a new battery but ended up ripping the door apart..... again (That butil tape defo seals well!) and swapping the door lock modual out. Now I can open the door without having to use the key and want to kick it
Broke the rear tailgate interior plastic trying to do the rear wiper bung mod - gave up after bruising my hand to bits and made the assumption is all held together with superglue. :rofl:
It is indeed but hey, I'm going to be keeping the car so will be good to have it looking it's best. Could have just done two doors and some scratches etc but would have regretted not doing the lot.
