19jeff89
67
Gave it a wash and wax
Sent from my SM-G930F using Tapatalk
Haze
344
Springs and shocks only been on about 2 weeks so might settle bit more yet. Thanks
Definetely got a little way to come down, that looks high. What exhaust you got on there buddy, cobra cat back?
Andrewwright
Turbo lover
Aug 16, 2016
1,567
224
Peterborough
Today is so fun, went to the garage to fill up some v-power to find now it's missing as soon as I leave the garage, to then be pulled over by the police "nice copper looked in the car and said nothing about it also said he hopes I fix it ".
Gonna check the filter/injector's/plugs. Work tomorrow so need to figure this out.
Changed plug=same
Changed coil pack over=same
bad injector maybe..going to get some and test
Code is p0304 on torque app
Fixed today. Had three leaking injector's and a bad coil after all...now pulling strong again, or so that BMW driver just found out lol
Sent from my Nexus 6 using Tapatalk
Suschef
105
Today we had new tires went for Dunlop sport maxx t2s all Round! Also found out the key is working which means something else isn't ;(
verbal_kint
639
31
North West Kent
Put a new tyre on, who leaves screws lying in the road!
Fitted rear "dash" cam. Now have to find out what the heck I've done to the seat belt return!
Changed sat nav hard wire over. first was not delivering enough to charge the thing.
Now the DAB cuts out when the sat nav is plugged in.
Seems like 2 steps back every time :(
Freed up the handbrake return and fitted a new spring.
DrewCole
Spannering the Cupra
Oct 19, 2015
696
Braintree, Essex
Got the Turbo off to find the oil leak...
Found it!
Masses of shaft play, rebuild the Turbo and now as it should be.
Refitting tomorrow.
DrewCole
Oct 19, 2015
696
Braintree, Essex
Put back together, sadly still smoking like a steam train.... so time to just go into the garage.
New wheels fit though!
Sent from my SM-G935F using Tapatalk
rogercupra
174
Stapleford Nottingham
I've replaced my sump on my lcr as when I did a oil change the previous owner must of cross threaded the drain plug as I couldn't get it to tighten up so I used some ptfe tape for a short time, I did check the oil before I started the car, so now that's been done I am a happy chap, next thing to do is to sort out both window regulators as the windows wont go down.
