gazjones
yea heard it in the vids you posted on the gti weekend sounds like you got a turbo back exhaust will have to see this on monday
gazjones said:yea heard it in the vids you posted on the gti weekend sounds like you got a turbo back exhaust will have to see this on monday
gazjones said:certainly sounds throaty makes mine sound weak and economical lol did you take it on the strip at santa pod?
gazjones said:lol im like that want to keep it clean but like it when it is a bit dirty cos ive got to clean it!
CupraTgirl said:I have just spoken to flash as he has worked it out and its running
183bhp
175lbs
bigjode said:Vag com is CRAP for working out Bhp and torque - well actually its not vagcom's fault, the car's reading of torque is very inaccurate.
CupraUK said:Don't use the bhp and torque from the ECU then... use physics:
http://forums.audiworld.com/vag/msgs/457.phtml
Scotty_b said:Flashy would you PM me the conversion formular for MAF g readings too BHp etc as i have some very high readings coming from my car! I know its not 100% acurate but puts a smile on my face!
Askara said:on the plus side... shes getting it RR'ed now.. so the wait is only so much longer!
Revo Kev said:...and then you might still not get an accurate answer as the the car could suffer from heatsoak on the dyno, or the operator might not be used to running VAG cars (or very good). Bear in mind you cannot take a result from one RR as gospel.
If you want to know whether your car is stock or not, you'd be best to meet up with someone that's got VAGCOM have a known stock car there and compare some datalogs; load 114, boost 115, MAF 002, etc. However even then you wouldn't know whether both cars are in the same condition so you could still see a difference between them. If you were to do this then a TBA (Throttle Body Alignment) on both cars prior to the test would be beneficial so the adaptation values are reset.
Values from the above logs could indicate if it's stock or not without comparison to someone that know's (or is used to) datalog values on these cars.
Hope this helps.
You could always pull your ECU out and have a look in to see if there's a chip on it! Wouldn't tell you if it's got software though.
