jason-jm
414
MAF AIRFLOW SENSOR SINGAL TOO LOW...
POWER SUPPLY TERMINAL 30 VOLTAGE TOO LOW
Charge pressure control positive deviation...
all sounds a bit scary top one is obviously maf.. but the other 2 :(
sounds like n75
Overboost. Your spiking too high coz of possibly a dodgy N75 or wastegate cranked too much.
You disconnected the battery is the other one.
Im ordering it this weekend providing the other two company's refund me my £170+ for the other 2 ****ed maf's
n75 cost much?
N75 are about £40 from vagparts. Im sure TTS Roadsport will be able to do you a good price aswell as Alex is a good bloke. Or you couls look second hand if you were tight for money.
I've changed both my MAF and my N75, still have positive deviation, limp mode all the time on spool up. My actuator rod is in standard position. Never get to the bottom of it.
Taken it back to 7 threads, still does it. Is it possible the actuator on the turbo is damaged causing this? Or is there such a thing as a faulty N112?
