Nutkin
Pop-a-Keg ya?
Aug 24, 2006
2,581
Schnaitsee
Right a kidn friend has offered me a set of
18" 5x108 ET 35Jaguar racing wheels.
Now how can i get these onto my car and lower it.
Can't be done :(
Maybe if the offset was greater you could get some hub adapters made up, but 18"s are generally 8" wide which doesn't leave much room between the edge of the wheel and the front wing
I've heard of wheels being re-drilled with stud pattern to fit to car. I personally think its a bit extreme. Have a word with an engineering company.
Oh, and wobble bolts? Heard of people using them to fit wheels to cars with slightly different PCD but dont know alot about them.
Phil .
I used wobblys to fit 100s onto my old punto which was 98. Don't think they would work on the difference between 100 and 108 though - that's a big difference.
exactly lardy, 2mm or 3 at most is fine, but 8mm on wobbley bolts!
they would be some fun!
na, most puntos have wobbley bolts! strange PCD, but 8mm out James is a bit too much! sorry buddy!
it can be done FK have the answer with pcd adapters you can change your pcd from 5x100 to 5x112 or 5x130, found them this morning while flicking through the cataloge. think they are around 118euros
