jetsetjimbo said:Cheers James!
Rud - do you have that PDF with your review of your suspension bits hosted anywhere as the westec one is offline now...
No I don't sorry......I'll PM Grant to see if he can restore it
Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
jetsetjimbo said:I know feel just did the rear ARB on standard suspension and he seems happy with it and didn't mention any odd handling characteristics.
jetsetjimbo said:Looking at the drop figures for suspension kits I assume they're based on the height of standard leon suspension?
Is the Cupra the same as any other Leon? I know the LCR is lower but how much lower as stock?
Ruddmeister said:It's difficult to get specific info when (as you say) the drop is from Std car rather than LCR ride height. It's still difficult enough to be 100% certain that the kit is specifically made for the LCR rather than just Golf Mk1V
Empi5 said:If u come on Sunday, I will chuck u the keys for mine, and you can go out and see for yourself. Ive got FK Silverlines,
jetsetjimbo said:Indeed and it seems that the majority of the resellers don't really know either. I've been looking at the KW stuff and it looks ok.
Were your PSS' confirmed as compatible with the LCR?
 Grant at Westec spoke with their Rep
 Grant at Westec spoke with their Repjetsetjimbo said:Indeed and it seems that the majority of the resellers don't really know either. I've been looking at the KW stuff and it looks ok.
 . I think i'd go out in phils car and see if you can live with the ride before committing to coilovers.
 . I think i'd go out in phils car and see if you can live with the ride before committing to coilovers.NeilC said:This conversations going a little different to sunday when you said you wanted to spend as little as possible to save for your wedding, but stop it leaning as much in the corners. I still think a 25 at the back best suits you (easier to hide from the missus. I think i'd go out in phils car and see if you can live with the ride before committing to coilovers.
	Ruddmeister said:Consider 28mm Rear and 25mm Front
Unless your missus spends her time lying down in the drive she'll never notice
Unlike 'some' people I'm not guessing if this works, I tried it and drove 20k Miles with it
jetsetjimbo said:It's really an either or for me at the moment.
ruddmeister said:In retrospect I think if I had to do it in stages then I would do this order.....
1 - Decent Rubber in lieu of cr@p Pirelli's + Dog Bone engine mount and front strut brace
2 - Coilovers
3 - ARB's
Darth Tater said:If you can't have both together mate go shocks first. Choice will most likely be based on your budget
On the ARB front I've got 28mm front and rear. I was gonna have same set-up as Rudd but BBT's advised going for the biggies all round. Seems to work ok at the mo. To be tested more fully this Fri on track
 and bigger ARB's on the front seems to improve things and not cause massive understeer as people had suggested, therefore 25mm on the front or more is what I would suggest
 and bigger ARB's on the front seems to improve things and not cause massive understeer as people had suggested, therefore 25mm on the front or more is what I would suggestRuddmeister said:Consider 28mm Rear and 25mm Front
Brucel said:Hi Steve
Your suspension there looks like it is lower on the right than it is on the left...?
The shiny metal bit is different?
Ruddmeister said:My comments were really related to Neil C's comments on the 25mm rear, I think 28mm is the better solutionand bigger ARB's on the front seems to improve things and not cause massive understeer as people had suggested, therefore 25mm on the front or more is what I would suggest
