In my eyes the biggest area of the LCR that needs improving is the cornering and I'm trying to decide where my money should go.
At the moment I can only afford ~£600 which really means I can do one of 2 things. Either Neuspeed front and rear ARBs, thinking 22 and 25mm as I don't want to go too aggressive or alternatively some coil overs.
Ideally I'd like the Bilstien PSS (ala Rud) as I don't want the car lowered any more than 20mm as it'll just get difficult to drive where I need to go - it can be bad enough as it is! Only problem is that these will well and truely blow the budget.
Is it worth getting the ARBs with the stock suspension or should I leave them and go for some coil overs instead?
) anyhow doing both front and rear ARB's is IMO the single best mod I ever did....go for a larger ARB on the front than you eprhaps thought (25mm front and 28mm rear was superb) I had very little understeer unless I was being very silly in the wet and preictable lift off oversteer.
