Hi, will the golf mk5 wheels fit onto my mk4 ibiza ? thanks mitch
SheffieldKid Bradz Aug 28, 2006 77 0 Sheffield Aug 4, 2009 #1 Hi, will the golf mk5 wheels fit onto my mk4 ibiza ? thanks mitch
Philleuh Guest Aug 4, 2009 #2 if you use adapters it will work(if the ET is right) otherwise not Golf Mk.5 (5x112) Ibiza Mk.4 (5x100)
SheffieldKid Bradz Aug 28, 2006 77 0 Sheffield Aug 4, 2009 #3 adaptors ? the offset is 54 is that to much and need spacers ? so the mk5 golf is 5x112 ? or have i just misunderstood ?
Philleuh Guest Aug 4, 2009 #4 SheffieldKid said: adaptors ? the offset is 54 is that to much and need spacers ? so the mk5 golf is 5x112 ? or have i just misunderstood ? Click to expand... If the offset is 54 then 20mm adaptors will work and the golf is 5x112
SheffieldKid Bradz Aug 28, 2006 77 0 Sheffield Aug 4, 2009 #5 so even with the ibiza at 5x100 they will fit a 5x112 stud pattern ?
st10587 i only brake for cake!!!! Oct 4, 2007 3,669 0 Hindhead Aug 4, 2009 #6 SheffieldKid said: so even with the ibiza at 5x100 they will fit a 5x112 stud pattern ? Click to expand... with the right adaptor
Philleuh Guest Aug 4, 2009 #7 SheffieldKid said: so even with the ibiza at 5x100 they will fit a 5x112 stud pattern ? Click to expand... with the adaptors it's possible yes
st10587 i only brake for cake!!!! Oct 4, 2007 3,669 0 Hindhead Aug 4, 2009 #9 https://www.dpmperformance.co.uk/wheel-adaptors-vag-5100-571-c-2803_2808.html
