Windows 11 24h2 sorting out those pesky drivers that stop it doing the second boot on the upgrade...
Tell
Taking 9 weeks to get a second laptop upgraded from 23h2 to 24h2 using either the ISO method and the rest. This time Microsoft bless them have changed the installation using a secure booting feature of Windows 11 in the upgrade process, if it fails the process you get an error code and masses of posts to look through on help screens. Support posts all the same stuff, which doesn't work....
If you started on this early, the idea of just waiting for Microsoft to sort it out hadn't come up, and I doubt they will for tricky machines unless they tell you the secret to be covered that I found, after nine weeks, in a small corner of the internet was the solution....
Story so far, it's easy to update relatively old unsupported hardware using the server method.
On Windows 11 compliant hardware it is more tricky, you don't use that method, if you are lucky then it's plain sailing which it was on this laptop HP Spectre x360 2-in-1 Laptop 15-eb0xxx using the Windows 11 Installation Assistant:
The Windows 11 Installation Assistant that shouldn't lead into any nasty first stage driver issues but may not complete giving a more vague error, or it could work first time.
Known issues are posted here:
You are supposed to wait to get the update invite but if you have a mixture of old hardware and new, the unsupported hardware will never get an invite so after doing them you get on with the ones using the official download page... should say at this stage since the bugs came to light in the update Microsoft would prefer you to wait...
If you don't and want to sort it out yourself as far as possible, then you enter the fun world if it goes wrong.
You are likely to hit this bank of codes:
  • 0xC1900101 - 0x2000c
  • 0xC1900101 - 0x20017
  • 0xC1900101 - 0x30018
  • 0xC1900101 - 0x3000D
  • 0xC1900101 - 0x4000D
  • 0xC1900101 - 0x40017
You only see those if you run the ISO. Running the ISO you don't take the preferred driver update that can land you with 0xC1900101 - 0x20017 which is an incompatible driver, and you end up in the boot screen. Multiple boots... going in and finding the correct old one and getting rid of the new one. You might be fortunate and never see that.
0xC1900101 - 0x40017 is the one you might see, which means you have a non-compliant driver or a non Microsoft virus program that needs uninstalling.
You get rid of the latter first. There are techniues to find them.
Here's the secret to find the non-compliant drivers in the second boot that Microsoft's hand out don't give to staff, so it seems. Appears in here:
Second post:
>>The following tool should tell us which driver(s) is/are causing the problem:<<
It's the memory integrity readiness Microsoft tool. That which easily exams the drivers, which will lead to difficulty on the second stage boot of the upgrade. There are two versions, AMD and ARM. Pick the one for your hardware.
Worked example:
Go to CMD and run as
hvciscan_amd64.exe > output.txt
Open in notebook:
>> VbsGetIssues: 0x00000000 VbsIsRecommended: 1 HVCI incompatible driver scan start... HVCI: "C:\WINDOWS\System32\Drivers\PxHlpa64.sys" failed with compliance failure mask 00000202 HVCI: Driver scanning complete HVCI: scan get result failed.
PxHlpa64.sys was the only troublesome driver listed....
Google gave: https://answers.microsoft.com/en-us...ble-with/1122bd64-57a7-41f7-a762-b13dac158562
Adobe DVD driver, try removing it:
From an Admin Command Prompt, run:
reg export "HKLM\SYSTEM\CurrentControlSet\Services\PxHlpa64" C:\PxHlpa64.reg
You should see the message "The operation completed successfully."
Then, run these two commands:
sc.exe delete PxHlpa64
ren C:\WINDOWS\system32\drivers\PxHlpa64.sys PxHlpa64.sys.old
Restart Windows.
Then run the update again. In this instance, it went on to full 24h2 installation :cool:.
The troublesome machine was HP Spectre x360 2-1 Laptop 16-f0051na, how the driver PxHlpa64 got in there pass, might have been part of the Adobe Lightroom software. Mystery. Out of 65 or so drivers, a bit tricky to find otherwise.
Essentially, as the tool throws up candidates, you check what they are from Google and try to work out why they are there. Then remove, like the example.
Best of luck, or just wait for Microsoft to sort it out... reckon it may take a time for troublesome setups.
Reactions: Zentrigue
Tell
Yes on the Microsoft board since then I've found quite a few people where it's helped as well (y). I just found it from 9 weeks of Googling the error reports. Extracting fragments and suddenly I hit on one of the beta testers telling someone you need to do a memory integrity test. Microsoft tightened up the backend security in 24h2 which gives you this problem if your drivers are non compliant. I did come across a bunch of posts where they turn backend security off, which is a more brute force fix for it. They probably didnt know it was memory driver integrity. Think the driver may have been in an older copy of Lightroom. I didnt want to delete it off the system.
Looks like 25h2 will be easy and the server method will work on unsupported machines as well. Should be smooth sailing.
