wiring in DRLs
RaviR50
2,756
Southampton
Guy just after some advice. Im trying to wire in some drls so i want them to come on with the ignition is there anything in the engine bay i can tap into?
Apr 12, 2008
1,197
The relays on the right hand side of the bulkhead both switched with ignition. Thin purple wires i finks.
Sep 29, 2008
835
Bradford
There is a thread on here somewhere, the guy who did it wired them into the existing light switch by removing one of the wires and inserting it it an empty slot which then allowed the side lights to switch on with ignition.
All you'd then need to do is take a feed from the side lights.
dgjdrummer
Part-timer
Nov 5, 2011
1,310
Wrexham, N. Wales
Not exactly the same issue bit something I was wondering - I have removed my passenger side fog light to create a cold air feed and never really use my front fogs anyway. Could I use the plug from the fogs to switch on my radiator fans?
The fans haven't worked since I've had the car and front fogs aren't a necessity so wondering if this might work rather than stripping out the fans completely for new ones or wiring in the resistor mod.
Cheers and sorry for the hijack!
