you know the price of
the ballasters
the bulbs
electric high adjust motor and did you mount the electric high adjust motor ?
or can i work with the manual ?
i know people that can fix de xenon in vagcom
so thats not the problem i just
I'm looking at fitting OEM xenons.
What exactly do I need? And what are the rough prices?
If you only want the xenons to light up, you need:
OEM headlamps about 600£
Bulbs 100£
Ballasters 100£ (used on ebay)
Adapter cables 40£ (kufatec.de)
VCDS coding free if you have one :)
Bulbs 100£
Sorry for bumping an old thread but I am about to do this mod. Care to share if it worked out for you in the end?
I did it with succes
and thought madsen TDi also
Are you happy with the result? got any pictures to share? is it just the list that was posted here or are other parts needed? also, are they self leveling?
Do you think the self leveling kit is worth it? How are your headlights set up right now by default? do the look ok? Also, what bulbs and ballasters are you using? oem? Do you have part numbers for the list? Last questions, can I you switch the angle of the beam according to left hand drive or right wheel drive from vagcom?
im gona instal zelf autoleveling but not right now
de headlights are from good quality (same as oem)
i don't now if i can switch from lef to right hand drive
the bulbs are D1s xenon bulbs
and the part number of the ballast are valeo G6 ballast (89034934)
4LO 907 391
hi.. i am also in the middle of doing the xenon conversion, got the headlights just no ballast but found some in the states and upgrading the D1S bulbs to 6000k :) just need to order the wire from kufatec. is that all i need or am i missing something?? not bothering with the self leveling or washers either just going to cover the plugs for the self leveling undernieth the headlights with an ally plate ;)
Bulbs 100£
What is the part number for the OEM headlamps?
Ballasters?
Bulbs?
