Anyone wants a stock Leon interior light let me know -you can have it for postage only![]()
Ditto.
If anyone wants mine, you can have it for the postage cost. It's just sat in the garage doing nothing.
Drop me a PM.
Ditto.
Drop me a PM.
IIRC a couple of others have done this mod too - and the one thing that sticks in my mind is the warning about screw lengths when fitting the new light - I know at least one person who ended up with two small bumps in the roof because the screws were too long!
I think your referring to the sunglasses holder muddy - my W8 doesnt use screws at all! It just kinda clips in!
No it wont - 2 problems:
The dimmer wire is in a completely different place.
The plug wont work in the Ibiza - The alarm sensors are in the way (for those that have them - most of us). You need to cut the end connector and solder the wires straight onto the W8 Circuit board.
EdButler
is the dimmer line necessary? does it just add the dimming light and if you dont connect it its just bright all the time or does it have to be connected to work altogether
yes
same shape same connections just has map lights in it done this with mine but black cupra one and all other cupra interior bits so it matches
All in all would people that have fitted the W8 light say that it is a worthwhile mod?
Bit paranoid about doing anything with the wiring TBH
