Thats where mine ran and i still had issues with water as it gets in under that box (seals on the box)
Lads there is a far far cleaner and easier way of routing the piping through the bulkhead, clicky for the details ive since moved the location of where i actually tap into the vacuum but same principal.
Is that not the same place as where I ran mine then??? Admittedly your photos show it better than mine - i didnt remove the scuttle panel - just lifted it up![]()
lol so its different then?
How did you get the bloody panel off! Mine never came off!
Just a few questions...... Has anyone else managed to get THIS gauge to dim? I found the dimming wire and connected it up, however it had little or no effect.
Also, what readings would you expect to get on a std LCR ? I'm seeing -30 at idle and a peak of around 11-12PSI under full load.
Cheers Rob/
