sonic_vi
Toledo 20vt
Hey guys
my remote central locking stopped working some time ago so i finally got around to buying a cheapo alarm off fleabay with remote central locking feature built in.
I figured i can probably fit it myself and it costs less than an auto electrician looking at it for an hour just to tell me its f**cked.
anyway all fitted and i have the cool "bwoop bwoop" when i lock and unlock (i know small things and all that)
basically i just need to know where is the best place to patch into the indicators?
there are 2 feeds coming from the alarm so can patch direct to wires.
I was thinking from the hazard switch as thats nice and easy to get to and the wires go straight to the bulbs as i want to patch in after the flasher unit.
Just need to know which wires on that lead to the bulbs?
If anyone has a pin out diagram of the flasher/hazard switch unit that would be most useful.
Russ ;)
Hey guys
Russ ;)
Did you manage to sort this problem out? Im going to be fitting a remote central kit shortly and will need to tap it into the indicators too... not sure if I should do it from the stalks or like you have from the hazards... can it not be done from the fuse box?
Right I seem to have located everything but the wires for window closure... there was supposed to be a blue box next to the black/brown in the kick panel.. but there is none...
