Hey looks really good...especially like the red.
Ziet er super uit...veel werk en geld in gezeten maar dan heb je ook wat. Ik ga zelf ook regelmatig naar biesheuvel, maar ben nog aan het sparen voor het grote werk. Maar wat is dfie pijp die via de linker kant naar onderen naar de Intercooler gaat? Die heb ik niet?
Maar super blijf zo door gaan.
Forgive my ignorance but what cooler is that? Piping route looks a lot safer than others... although you clearly have to change a few parts
bought the cooler from ebay, the piping left from the motor block are from a audi TT
standard audi tt has a silencer near the turbo, they removed it and welded a new piece to the turbo :whistle:
this is the silencer and pipe from a audi tt
Biesheuvel doesn't have red hoses.
I bought them from I.Q parts.
The left pipe is from the turbo.
The other goes from the cooler to the manifold.(havent got those standard)
did you have to move the radiator back?
what are the dimensions of the intercooler? (height, width, length?)
So let me clarify -- is that an aftermarket "hot" pipe for a TT FMIC? (as I thought TT's had the same wing mounted set-up as the ibiza) with the silencer cut off and some extra pipe welded in to attach to the turbo?
And the cold side is totally custom?
no, its not aftermarket
just a normaal TT pipe with brackets and stuff, without a silencer and welded with some extra pipe
cold side is custom
they moved the AC to get more room for it and adjusted the crashbar
outside measurements 700x180x65mm of the FMIC
cooling side measurements 550x180x65mm of the FMIC
connection measurements are 57 mm of the FMIC
i have all the veyy same stuff ready to go on
how much did you trim from the bumpper?
where did you get your charge pipe from?
so the AC has not been removed? just moved backslightly?
also, do u have a list of all the silicone pipes that were used?
i am very keen on going this route... it looks really good!!
dont suppose you fancy selling me your ibiza charge pipe do you the crossover pipe, i need one to tidy up the fmic install on my golf. nice work youve done there, did you do it yourself?
de leon cupra r has got the same pipe i think, dont know if it fits alright
but the tt pipe fits perfectly, just search on an auto junk yard or whatsoever
it could save some money
yep the leon cupra r one is the same
