You must have strange sex then my friend.
Try lube.
i used a dump valve because i wanted the noise LOL!
The only disadvantage i can see from using a re-circ / boost retrun system is that as air passes through the charger it is heated (as a by-product of compressing it). If you then take this heated air and dump it back into the system before the charger it will have to go back through charger and be heated again. so you are constantly re-heating air that you ideally want as cold as possible
the coolers pipe ares 56mm (2 1/4") and it's a medium intercooler from universal intercoolers. Amazing quality and only £125 *shameless plug over lol*
