knotty
Pocket Rocket
Oct 9, 2007
118
Shotts, Scotland
Fitted my boost gauge today and took it for a test drive...
now just before i start the gauge is connected to the small hose coming off the top of the DV the gauge also shows vacuum pressure so i can check both
now during boost its only peaking at 8psi ... does this sound normal for a standard mk3 cupra with only a forge 007 fitted?
the vacuum is reaching 30psi when off-boost
i figured it would be around 12-14psi standard so hopefully someone can give me an idea
wouldn't recomend taking the vacum of dv i would recommend inlet manifold. The dv doesn't what to be disturb really only my personal opinion thou'
Even the trail version would peak higher than 12psi. More like 19/20psi.
Im sure -vac pressure should read around 20.
:yes: I saw 22psi on stage 1 that was with the SPS setting knocked up to HB9.
Trial version maybe slightly lower as its a slightly differant code.
apprently not as powerful so i have read.
after last night it peaked at 15/16psi but as mentioned above revo trial is not as powerful, they guy in the garage told me they were unable to change the boost settings on trial mode but when putting stage 1 on they could up the boost so 20-22psi is manageable
even on 15psi what a phenomenal difference i felt, i had been putting the foot down before i got it revo'd then straight after tested it, needless to say i was pinned to my seat it was that quick. (was great to hear noise from my DV lol)
The vacuum pressure is dropping to -25 not -30 as previously stated, i wasnt staring at it so it looked like 30, so the readings look all good so far doesnt look like theres any problems.
oh its a savage boost gauge i use.
not too happy now the revo has worn off my boost is only peaking at 5psi
which is rather lame considering it "doesnt affect standard software upon wearing off"
it will be in your head cause your car felt so much faster just go and pay for the full version and you will be happy again mate.then after that you will always crave more power
