Fitted my boost gauge today and took it for a test drive...
now just before i start the gauge is connected to the small hose coming off the top of the DV the gauge also shows vacuum pressure so i can check both
now during boost its only peaking at 8psi ... does this sound normal for a standard mk3 cupra with only a forge 007 fitted?
the vacuum is reaching 30psi when off-boost
i figured it would be around 12-14psi standard so hopefully someone can give me an idea
I saw 22psi on stage 1 that was with the SPS setting knocked up to HB9.
