Resistors Thread..
cus
... Vag only!
Feb 8, 2004
1,713
Middlesbrough
www.nemm.co.uk
I don't know if this is a good idea or not.
But i was thinking that people can list the different resistors used for mods on their car . e.g.
n112 valve
n249 valve
carbon canistor
pictures would also be pretty good. I guess this will stop a lot of threads asking about resistors and stuff. Plus it'll also help me out as well!
Nov 2, 2004
9,335
South Wales
I've read that a 330ohm 1 watt resistor will work, i know the one i have on doesnt work which is something like a 33ohm 10 watt.
So i'm sure a 330ohm 10 watt one will work. I need to try it out.
Nov 2, 2004
9,335
South Wales
The ones i posted up are the correct ones for everything, N112, SAI, N80.
You'll need 4 if doing it properly. 3 if you dont bother with the SAI pump, which i've left and i've never had a code from it.
Spud_G40
PS3 Gamer tag: SRedx
Jun 12, 2006
397
Glasgow
Could you guys tell me what exactly you have to do to fit these? As i've just removed my SAI. I undertstand car mechanics side of things, just not the electrics or wiring. Cheers.
cus
... Vag only!
Feb 8, 2004
1,713
Middlesbrough
www.nemm.co.uk
cut the old connectors off, and the 2 wires left 0ver need to be to placed at either side of the resistor.. then either wrap them together or solder. then use loads of electricians tape to hide it and protect it from the elements. done mine now and it looks OEM :) very happy.
btw spud, is your car yellow or orange!? cant really tell from the pic
Spud_G40
Jun 12, 2006
397
Glasgow
Ok cheers mate, I take it it does'nt matter which way round? Is there not 3 wires going into the multiplug on the SAI pump? Need to double check.....
LOL, my car is actually flash red, very bad quality phone in a brightly lit garage. Need to change that pic now :)
flooky
Does anyone have any pics of installing, hiding them? I understand where they go and how but I received mine today and their MASSIVE! same ones as in the link from RS that Chris posted up!
Jan 8, 2007
2,958
Wiltshire
Thinking of removing my N249, N112 and SAI next week. Am I right in thinking I need 3 resistors for this? One for each N112, and one for the SAI pump connector? Just want to be sure.
EDIT: Read a couple more related threads, so that'll be a yes :) Or in Phil's case, take a chance and you may be lucky
