guys as much as I appreciate the banter, its not really relevant to the thread, thank you
anyway tightened the bolt on the car that I could get to, and as soon as I do, it pretty much works itself loose again!
boost feel really jerky now and a definite drop in power thats for sure!
Wednesday can't come soon enough
I had the same problem with my old backdraft kit(same responce "your the only one"), I ended up getting some proper studs, nuts and washers that you tap over the nut and manafold or downpipe (they look like normal washers with two tags) from Owen developments who told me they have seen the same problem on evo etc, after fitting they never moved again. I did try everything and this is the only thing that worked for me.
