Nev_LCR
Gone... but not forgoten
May 16, 2007
1,271
Ipswich, Suffolk
can anyone post pics on where to T the boost gauge,
mine is off the top of the DV at the moment but read a few threads of better places to T from for a better reading,
but i need pics of where this should be.,
cheers
cheers
are you running a split r dv? otherwise id t off the top of the dv. i get a consistant figure from this position with no problems. are you having issues or just not confident?
try searching FPR as i think its the only other option
Took mine of the FPR, as the DV get's it vacuum (controlled) from the N249 (think that's right)
Correct!
Best place is is to Tee into the vacuum line running to the FPR, that's on the right-hand end of the fuel rail on top of the inlet mani on the LCR.
