Nice... What kind of W/M system are you looking for ? I assume, that you are going to run APR 100oct file :)
Getting the 2.0T snow performance kit.
In regards to software, im going to run it on the current map. I dont think APR have a 100oct calibration for Europe. Someone at APR is running it on his Stg3 setup ok with the normal software.
Car booked in on the 29th for:
Peloquin Diff
Fitting of rods
and water/methenol injection kit.
Aiming for 430hp :whistle:
If there is not a 100oct map (104-105RON) for your ECU at the moment, you could still have it. I prefer more 104oct map for w/m system than your current map...More timing and better powerband etc... Just ask it from Keith or Mike... I asked from Keith 104RON map for K04 and he said that I could have it if I want, but now I dont need that anymore :p
Yes, after conversation with Arin@APR , im going to try the 104RON map. I wont use it permantly though, as there is a risk of using this map if the W/M fails.
Yep.. Good decision ;)
I think so that Snow has flow meter on their current product list ? If the w/m system fails you can still drive your car, but just dont go to boost area... Those w/m system are quite safe and I havent read once, that someones system was failed...
I'm thinking myself to get Aquamist system + flow meter, but we will see that later ;)
Peloquin Diff
Fitting of rods
Dan was ready about the guy with 507 NM of torque destroying his drive shafts, you having to do anything to stop this happening to your car?
