james walker
cooling is the key people
May 24, 2007
5,121
retford notts
as in title, whats the best options to upgrade rears on leon cupra, to get rid of the teacup discs.
got my 996 fronts on which look mint, and the rears look pap!!!
i want them to look good and improve braking further...
price, options etc, all advice taken
cheers:D
ECS two piece 308mm setup.
Just under £500 I believe for discs, caliper spacers and bolts.
Improved looks and braking.
You need to retain the stock caliper (or at least one with a handbrake cable) so just fitting bigger porsche items is not that easy...
ha ha, bigger rears than the fronts, now that would be fun....
was thinking more along the lines of a 256mm setup.... whats all needed for this?
so will a 256mm rear conversion from a cupra r fit strait onto a cupra?
also, will the bias be ok, still on stock 312mm but with porsche 996 4pot brembos....
is the cupra r standard rear brakes 256mm ?
they look really small i think on my cupra r. in comparison with the from brembos, so maybe u should look further for some slightly bigger ?
big rears on a fwd to me does sound a bit OTT, as the rear end will already be braked adequately on 256mm vented rears... 4WD A3 quattro, S3 etc would likely benefit more as they are heavier rear ended.
I know on my race ibiza, I run stock rear 232mm non vented rears on stock pagid pads, and still wind off the rear brake bias as they brake too much.
Your not going to sell many 330mm rear kits saying this, lol
what about a 2 piece 256mm x 22mm bell/rotor
I am not a salesman.
no rotors available in that small a size..
go LCR rears if you want a bit bigger and vented imho
supersize rears on a fwd is not something I would want to leap too untried.
Anyone want to be a guinee pig?
I will volunteer myself as the guinea pig for some big rears but need to buy a couple of tyres and do the front brakes first too, they have pretty much had it.
You will probably be getting a phone call off me soon Bill as well to upgrade to the 2 piece front setup, as i would like to start doing some track days this year
