removing the steering wheel
Altech
Ibiza PD170
Oct 3, 2007
1,996
London
- Firstly disconnect the battery.
- Then locate the two holes at the back of the steering wheel which house the securing clips for the airbag.
- Once you find the holes, insert at stubby screwdriver or something to undo the clips.
- Once the airbag is released unclip the wire that connects it.
- Then there should be one main bolt that secures the steering wheel to the column. Undo that and the wheel should come off.
nathibizafr
u no when you put the screwdriver in the whole what do you do jus wiggle it or move it up and down it does seem to be coming off
there should be a detonator behind the air bag if its the same behind there as the octavias. with a yellow dot in the middle i believe make sure that dont go over the green lines either side of when removing. i thinks thats the right colours anyway.
im not even sure the seat range have them but i know the octavias do from when i worked there.
you dont even have to disconnect the battery its just a precaution either way dont turn the ignition on in the process.
