Which Cupra R Recirc Valve?
dentist
68
As the Proud owner of a new LCR, this car is my first turbocharged car and i've always wanted that "dump" valve noise.
I'm caught between the Forge 007p and the Splitter R Recirc Valve, What are the major differences between the two and which is louder? Also, how hard is fitting either (Im a total newbie to turbos!)
The LCR is not remapped,no milltek, and will have a neuspeed flow kit to be added asap.
All help appriceated in advance!
AJ
Richie-LCR
139
ayrshire
AJ
the 007p is the quiet one and the splitter gives you the woosh noise so you'd ba after the splitter
fitting guide from a post below this one http://www.forgemotorsport.co.uk/media/USASPLTR.pdf
HTH
dentist
68
Cheers Rich! thanks for the quick response, better get on the phone to awesome GTI!
R Power
R Power
May 19, 2008
138
Coventry
Welcome to the scene!!
majority of people including me would recommend the 007p over the split R. the split R is designed to let out around 40% of the pressure into the air to give you the woosh noise (according to forge), i had this on for about a month and gave it up straight away as it kept sending my car into 'limp mode'!!!
the full recirc valve which is the 007p i would recommend as the LCR's need all the pressure back in the system so i heard, and i also beleive very much. you can hear a slight dump noise when sitting inside the car, but the main thing to be sure about is your car will run the right way.
