when you have onvi 'slightly less yellow than it should be' and the spoiler is the right colour
When you put your foot down and the stereo gets louder!
cold beep and fuel beep scare the **** outa me
You **** yourself every time the cars low on fuel or the temp drops below 4.0Deg!
The later Alana headunit plays mp3 cdsi wouldnt mind so much though if it played mp3 discs.
When you pull the handle on the front seat to get into the back, and it comes off in your hand!
Also, when to lights mist up randomly regardless of weather (have found a cure for this though
other than that, i adore the old girl (in flash red she's a stunner!)
drill two holes in the back plastic cover (the bit with the metal clips on)
p.s if anyone does find a cure for the rear lenses, let me know, taking the covers off does nothing, i may have to remove the entire unit
Try leaving the lights on with the covers off and wait for them to dry, then put the covers back on. Try this on a dry dau so no moisture gets in. Or you could try a hair dryer, I know several people have done it this way with some success.
