tanyacop
Sum bloody twat pulled out on me 2day so i went 2 beep erm but no horn! he got the point wen i did handsigns but need me horn back! ne ideas peeps?
Same thing happened to me. It was the horn itself. If you can get it out, I think it is the front passenger side if memory serves me, try hooking it up to a battery just to make sure it is dead.
I replaced mine with a louder two tone one, for just such an occasion!!!
I had to replace mine. It was a bit fiddly in my case because the replacement horn was a bit bigger. The horn is bolted on just under the front passenger corner of the car, and its just a case of unbolting and disconnecting the wires, and whacking the replacement in.
Great!! I'll have a butchers this weekend, been on Halfrauds website and seen 1 or 2, go on Fleabay tonight :headhurt:
You might manage with just removing the under tray but I doubt it.
Just cut the wires to the stupid thing, remove the passenger arch liner and bolt a new one into the space there - unless you have twin sidemount intercoolers in which case you won't because the space I'm referring to is already taken.
Nothing stopping you mounting it elsewhere though - just as long as you can get to the wires to connect it all up :)
