No beep beep!!!!!!!!!!!
tanyacop
Sum bloody twat pulled out on me 2day so i went 2 beep erm but no horn! he got the point wen i did handsigns but need me horn back! ne ideas peeps?
ell0070
208
Jersey, Channel Islands
Same thing happened to me. It was the horn itself. If you can get it out, I think it is the front passenger side if memory serves me, try hooking it up to a battery just to make sure it is dead.
I replaced mine with a louder two tone one, for just such an occasion!!!
ell0070
208
I had to replace mine. It was a bit fiddly in my case because the replacement horn was a bit bigger. The horn is bolted on just under the front passenger corner of the car, and its just a case of unbolting and disconnecting the wires, and whacking the replacement in.
Teasy
451
Middlesbrough
Great!! I'll have a butchers this weekend, been on Halfrauds website and seen 1 or 2, go on Fleabay tonight :headhurt:
UncleFester
Grumpier by the day!
Apr 30, 2006
4,764
Milton Keynes
www.facebook.com
You might manage with just removing the under tray but I doubt it.
Just cut the wires to the stupid thing, remove the passenger arch liner and bolt a new one into the space there - unless you have twin sidemount intercoolers in which case you won't because the space I'm referring to is already taken.
Nothing stopping you mounting it elsewhere though - just as long as you can get to the wires to connect it all up :)
