mrwookie
Big Daddy...
Mar 22, 2008
716
Cambs & Herts
Ha ha... bet your missus is more worried about giving birth to a wookie!:cartman:;)
Yea poor kid's gonna be tall even if he/she doesn't like it...
Not the best bud, look good but not the best safety results.
Leave it to your wife, she'll do all the hunting, all you'll have to do is the paying, lol
I had heard they were more form than function. I'll just do the paying......oh lordy!!
mrwookie
Big Daddy...
Mar 22, 2008
716
Cambs & Herts
Hello mate, threads a good read.
Is your green cotton and dule cone?
Cheers Nick its getting there slowly. Yea the Green Cotton is the dual cone one although not using it at the mo as the car runs and flows better with the Powertec fitted. I can only assume that this is down to the fact that it has ultra fine stainless steel mesh rather than fabric so less resistance. Also no oil or other addivtive that may help push the MAF over the edge.
Skorchio
600 Miles to a tank :)
Jan 23, 2007
1,569
Nr Milton Keynes
Hmm im beenthinking about trying out a Dule cone, can get one on trial so ill give it a go and see what logs i get :) Does you current flow more than the CDA? Be good to bolt my dyna twist on and see what you get with that!
mrwookie
Big Daddy...
Mar 22, 2008
716
Cambs & Herts
Yea open cone flows more compared with the CDA. CDA was flowing around 186g/s I think it was and open cone was flowing 204g/s. Since having head work done now peak flow has been 216g/s.
If your trial doesn't materialise or to much faff mine is just sat in my shed here which your more than welocme to use. :)
mrwookie
Big Daddy...
Mar 22, 2008
716
Cambs & Herts
Jesus, that HUGE increase! Im going to be getting my hands on a open cone! Where you get ur powewtec from?
Bear in mind I had the head ported and polished when all off but yea not bad gains.
Got the filter from Flea bay.
http://cgi.ebay.co.uk/POWERTEC-Induction-Kit-Seat-Leon-1-8-T-Cupra-R-PT36-10_W0QQitemZ200345981118QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item2ea58d10be&_trksid=p3286.c0.m14&_trkparms=65%3A12|66%3A2|39%3A1|72%3A1683|240%3A1318|301%3A1|293%3A1|294%3A50
Skorchio
Jan 23, 2007
1,569
Nr Milton Keynes
Still 204g/s is a very good flow, your running stage one arnt you? What boost you running? That 216g/s is alot of air, you still on 3bar injectors? You logged you injector duty cycle? Aaron and me and running 216 ish and we ware on 433cc injectors.
You comming to the show on sunday? Id like to try your green filter :)
mrwookie
Big Daddy...
Mar 22, 2008
716
Cambs & Herts
Yep running stage 1 CC map at the mo on standard injectors. Boost is shown below, a slightly lower flow on this one,.... and what show? You meaning Inters?
Anyway logs...
Code:
Group A:	'003				Group B:	'115
    RPM Mass Flow Load	Ign. Timing		RPM	Load	Absolute Pres.	Absolute Pres.
TIME					TIME
STAMP	 /min	 g/s	%	 °BTDC	STAMP	 /min	%	 mbar	 mbar
80.07	3640	101.39	98.8	18	79.77	3560	117.3	1680	1450
80.67	3840	123.14	100	15.8	80.37	3760	147.4	1710	1710
81.38	4120	169.42	100	7.5	81.07	4000	191.7	2260	2330
81.98	4360	165.14	100	9	81.68	4240	191.7	2250	2440
82.58	4600	162.06	100	9.8	82.28	4480	191.7	2250	2340
83.19	4800	170.61	100	11.3	82.88	4680	184.2	2220	2260
83.79	5000	175.36	100	12.8	83.49	4920	186.5	2240	2200
84.39	5200	186.31	100	12	84.09	5120	183.5	2260	2240
85	5400	193.92	100	12	84.7	5320	189.5	2290	2270
85.6	5600	200.36	99.6	9.8	85.3	5480	183.5	2330	2260
86.2	5760	204.92	100	10.5	85.9	5680	187.2	2340	2270
86.81	5960	206.58	99.6	12.8	86.52	5880	180.5	2330	2260
87.41	6120	208.25	99.6	11.3	87.11	6040	179.7	2300	2250
88.01	6240	210.89	100	9.8	87.72	6160	182.7	2240	2200
88.62	6400	209.22	99.6	11.3	88.32	6320	172.2	2190	2210
89.22	6520	211.25	99.6	10.5	88.92	6480	173.7	2140	2150
Skorchio
Jan 23, 2007
1,569
Nr Milton Keynes
Hmm 18 PSI, with that much flow is VERY good, Get its to 22 PSI and see how much its flowing then!! Have you done much else to improove flow?
Can you log 002 and 031 so we can work out ur injector Duty Cycle and see what you AFR is, thats allot if air for your injectors?
Skorchio
Jan 23, 2007
1,569
Nr Milton Keynes
Not inters mate, Its Dutchconnection i think.
Deutsch Connection - Sunday 14th June 2009
jabre
questions
Hi there mate,
I am pretty new to the LCR fan club and I have recently bought a standard example myself about 4 weeks ago now.
I have been reading through all your posts and I like the mod's you have done to your LCR.
I reckon in a few weeks when I have a bit of spare money I will embark on some mod’s myself. Maybe, FMIC, Sports cat and exhaust, Remap, Etc.
I was just wondering if you could explain to me what they actually mean by hybriding a turbo and what sort of HP gains do you get from it and is it a cheaper way of getting the LCR's power nearer to 300HP than a BT conversion????
Also you mention 'logging' quite a lot. How do you do the logging and do you have the details on what I could do to do the same on my LCR????
Cheers mate.
