VAG-Veteran
When i lock my car i get a very faint click from under the front scuttle panel but no beep.
Is this normal and do i need to have the beep set up on vagcom?
Or is the beeper ****ed?
no beep unless its programmed tobeep on vagcom, but i read somewhere this is illegal???
Well i am dont know whether it is knackered or not.
It does try to make a sound but it sounds like a click from under the scuttle panel so not sure.
didn't know mine had an alarm until I set it off...mines makes an ever so slight beep or chirp when I lock it, it's about the same volume as the locks but deffo a beep/chirp. as above it should be something that can be switched on/off with vagcom
