Pacey
258
Northants
hello boys and girls
Need help please asap fitting new disks and pads all round fronts sre done i think but cant get the calipers off the back! WHAT SIZE ALLEN KEY DO I NEED????
thanks in advance Pacey
You'll need a calliper wind back tool but you don't need to remove the 8mm allen key headed bolts. Back off the 13mm bolts, remove the pads and piston. Back off the disc screw, change the disc, wind back the calliper piston, fit new pads and calliper, job done
Halfords, you seemingly can do it with long nose pliers spread open and located into the slots on the piston and rotate these to wind back
