Found a cheapish Forge side mount intercooler, is it really worth buying one, or the difference from oem wont be worth it? Its 27 mm x 5 mm x 15 mm bigger than the OEM cooler.
Pressure loss reduction: 2psi
Air temp reduction: 6-9 Deg.C
what do you reckon? im aiming for 230 hp with a Forge TIP, 007p dump valve, stage 1 map, decat. Will that intercooler help?
