Manual Boost controller issues - help please
jamiebennett81
ok, tried fitting the MBC today and I am confused
I understand you still leave the N75 plugged in electronically - DONE
the N75 fits into the TIP, so I took it out and blocked off the TIP - DONE
the vac line from the actuator fits to the underneath of the MBC - DONE
the vac line into the charge pipe runs onto the side inlet of the MBC - DONE
MBC is wound right down and its running silly boost
what am I doing wrong?:confused:
wild willy
2,323
Wales
You've plumbed the mbc in wrong.
The boost feed from the charge pipe feeds into the botom of the mbc (assuming a forge unos). The output from the mbc (side) feeds the actuator hose. ;)
happy days.
wild willy
2,323
Wales
Also start with the mbc with the stronger of the two springs wound to its minimum setting.
ie strongest spring on lightest setting..... NOT WOUND UP TIGHT.
increase load by two clicks at a time, logging in between. Don't exceed 1.5 bar max boost.
My disclaimer.......... Jamie it was looking good the last logs we saw please don't blow it up. :cry:
jamiebennett81
thanks but I have tried this....either configuration of the pipes plumbed into the MBC you get silly boost
hence I am confused
jamiebennett81
stronger of the springs is also in and wound to it's minimum setting
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
Tony.. I've told you this already?!?!?!
boost goes into the base of the forge mbc, is exits out of the side to the actuator.
jamiebennett81
sorry, just checked your email:whistle:
plumbed in correctly and just went out for a drive, still running silly boost
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
when I ran the same type on matts briefly, I set it up on my compressor so I could dial in the leak pressure on the regulator so I knew roughly what psi it was going to start opening at.
do you have a softer spring to put in?
is it wound all the way counter clockwise?
jamiebennett81
sorted
changed the spring for the softer one and its now boosting to 1.1 bar, with some quick initial adjustment, now showing 1.2
will dial in more when I am out logging, so to make sure everything is OK
thanks for the help:)
jamiebennett81
:thumbup:
your a serial fiddler are'nt you :)
:lol:
he he, yes I am
just seeing the differences really
after all of this I may switch back to the N75. the MBC made a big difference with the ever failing gt2x setup, just interested to see how it reacts with a hybrid k03
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
he he, yes I am
lol - reading it back, I did'nt mean fiddler as in, erm, you know, fiddler... :hide:
mbc should produce good results on yours... its a peppy thing.
remember milage on engine and 19mm rods.. ;)
jamiebennett81
:cartman: - no worries Bill
oh yes, sticking to the 1.4 mark and not going past it
logging tomorrow night so will post up results
